*maploadtomesh
Creates loads on an FE mesh that correspond to a load on the underlying geometry.
*maploadtomesh markmask
HyperMesh Tcl Modify Command
- markmask
 - ID of the entity.
To create temperature loads on an FE mesh that corresponds to the given geometry load
*createmark(loadcols,1) "m"
*maploadtomesh(1)
      This command is applicable only from HyperMesh 6.0 onwards.
None.
