*morphvolumeequivalence
Joins morph volumes on a mark together which are within a specified tolerance.
*morphvolumeequivalence c_entity_type c_mark_id tol tan nauto
HyperMesh Tcl Modify Command
This command will join all morph volumes on the mark whose faces are within a set tolerance. Creating tangency between joined morph volumes and automatic registering of nodes inside reshaped morph volumes are optional features.
c_entity_type
Must be set to hypercubes.
c_mark_id
The mark ID of the hypercubes. Valid values are 1 and 2.
tol
Maximum distance between morph volumes for joining.
tan
0 - Do not create tangency between edges of joined morph volumes
1 - Create tangency between edges of joined morph volumes
nauto
0 - Do not register new nodes
1 - Register new nodes
To join all morph volumes which are within 10 model units of each other:
*createmark hypercubes 1 "all"
*morphvolumeequivalence hypercubes 1 10.0 1 1
Incorrect usage of *morphvolumeequivalence results in a Tcl error. To detect errors, you can use the catch command:
if { [ catch {*morphvolumeequivalence hypercubes 1 10.0 1 1} ] } {
# Handle error
Version History
10.0
