*segmentsetcreatewithshells
Creates a segment set using 1D or 2D elements.
*segmentsetcreatewithshells name color mark_id reverse_normals
HyperMesh Tcl Modify Command
- name
 - The name of the segment set to update.
 - color
 - The color of the segment set. Valid values are 1-64.
 - mark_id
 - The ID of the mark containing the elements to add. Valid values are 1 and 2.
 - reverse_normals
 - Create segment set:
Examples
*createmark elems 1 1-100
*segmentsetcreatewithshells "test" 5 1 0Errors
   # Handle error
}Version History
2020
