*elementqualitycollapseelems
Collapses/combines two adjacent trias into a quad.
*elementqualitycollapseelems elem_id1 elem_id2
HyperMesh Tcl Modify Command
This command collapses/combines two adjacent trias into a quad.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
Current element quality criteria for optimization must be set before using this command. The command may be applied at any time without resetting the current quality criteria.
- elem_id1
 - The first tria element ID.
 - elem_id2
 - The second tria element ID.
*readqualitycriteria c:/criteria/mycriteria.txt
*createmark elems 1 displayed
*elementqualitysetup 1
*elementqualitycollapseelems 10 11
*elementqualityshutdown 1Errors
   # Handle error
}Version History
13.0
