*filtertable
Filter unique cells of key strings of selected column(s) and generate a new table considering the indices of key strings in key columns.
*filtertable table=<name> keystring=<string1, string2, ... stringN> keycolumns=<column1, column2, ... columnN> valuecolumns=<column1, column2, ... columnN> targettable=<name>
HyperMesh Tcl Modify Command
Unless otherwise noted, all inputs are mandatory. They may be specified in any order.
- keycolumns=<column1, column2, ... columnN>
 - The key columns of the selected table, separated by commas. These must follow the same sequence as the keystrings.
 - keystring=<string1, string2, ... stringN>
 - The key strings of the selected columns, separated by commas. These must follow the same sequence as the keycolumns.
 - table=<name>
 - The name of the input/source table.
 - targettable=<name>
 - The name of the output/target table.
 - valuecolumns=<column1, column2, ... columnN>
 - The value columns of the selected table, separated by commas. These must follow the same sequence as the keystrings.
Examples
*filtertable table=sourcetable keystring={2,2_3_0} keycolumns={layerindex,loadcase} valuecolumns={elementid,TAU12} targettable=targTableErrors
   # Handle error
}Version History
2020
