*solid_fixedptsmaker
Used in the Solidmap panel to create fixed points on the edges of selected components. These points are generated from nodes on the component’s edges that fall within a specified tolerance, and are meant to be transitory.
*solid_fixedptsmaker surf_mark_id comp_mark_id tol_rel
HyperMesh Tcl Modify Command
Used in the solidmap panel to create fixed points on the edges of selected components. These points are generated from nodes on the component’s edges that fall within a specified tolerance, and are meant to be transitory.
surf_mark_id
1 or 2, surface mark ID. Fixed points are to be made on the edges of these surfaces.
comp_mark_id
1 or 2, component mark ID. Nodes of the elements in the marked components are considered for making fixed points.
tol_rel
Tolerance relative to the average element size calculated from the elements in the inputted components.
To create fixed points on the edges of surface 10 considering nodes and elements from component 3 with a relative tolerance of 5:
*createmark surfs 1 10
*createmark comps 1 3
*solid_fixedptsmaker 1 1 5
None.
