*setsurfacenormalsdisplaytype
Sets the display type for surface normals.
*setsurfacenormalsdisplaytype type
HyperMesh Tcl Modify Command
This is utilized by the commands that turn on surface normals display.
type
0 - Vector display
1 - Color display
To set the surface normals to color display, and turn on the normals display of surfaces 1-10:
*setsurfacenormalsdisplaytype 1
*createmark surfs 1 1-10
*surfacedisplaynormals surfs 1 0
None.
