*isolateelementswithinradius
Isolates entities within the radius specified.
*isolateelementswithinradius entity_type mark_id radius
HyperMesh Tcl Modify Command
Isolates entities within the radius specified. Other entities in the model should be hidden first.
- entity_type
 - The type of entity to isolate. Valid values are masses and elements.
 - mark_id
 - The ID of the mark containing the entities to isolate. Valid values are 1 and 2.
 - radius
 - The radius of interest from all locations.
Show elements from all locations of mass1 and mass2 within radius 50.0:
*createmark masses 1 mass1 mass2
*isolateelementswithinradius masses 1 50.0
   # Handle error
}Version History
2017.2
