*elementqualitysplitelem
Splits a quad element into two trias.
*elementqualitysplitelem elem_id
HyperMesh Tcl Modify Command
This command splits a quad element into two trias.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
Current element quality criteria for optimization must be set before using this command. The command may be applied at any time without resetting the current quality criteria.
- elem_id
 - The quad element ID.
*readqualitycriteria c:/criteria/mycriteria.txt
*createmark elems 1 displayed
*elementqualitysetup 1
*elementqualitysplitelem 10
*elementqualityshutdown 1Errors
   # Handle error
}Version History
13.0
