*rigidlinkinodecalandcreate
Creates a rigidlink elem by calculating the independent node based on selection of dependent nodes. Location of independent nodes will be at the geometric center of dependent nodes.
*rigidlinkinodecalandcreate node_mark1 set_id attach_set_option dof
HyperMesh Tcl Modify Command
- node_mark1
 - Mark for multiple dependent nodes.
 - set_id
 - Set that contains dependent nodes. Set type should be of nodes.
 - attach_set_option
 - Options for attaching set to rigidlink:
 - dof
 - Degrees of freedom. This is a six digit number.
For creating a rigidlink elem by selecting only dependent nodes without the attach set option:
*rigidlinkinodecalandcreate(2,0,0,123456)
      For creating a rigidlink elem by selecting only dependent nodes with the attach set option:
*rigidlinkinodecalandcreate(2,0,1,123456)
      For creating a rigidlink elem by selecting only dependent node set with the attach set option:
*rigidlinkinodecalandcreate(0,2,1,123456)
      *createmark() for nodes is required if a dependent node set is not selected.
None.
