*tableinsertcolumn
Inserts a column of data into a table.
*tableinsertcolumn name data_type column_label string_array number_of_strings column_index
HyperMesh Tcl Modify Command
name
The name of the table to update.
data_type
The data type of the column. See *tablecreate for valid values.
column_label
The label of the column.
string_array
The ID of the string array that contains the column data to add. The string array is created using the *createstringarray command. This should always be set to 1.
number_of_strings
Integer indicating the size (number of strings) in the string array created using *createstringarray. This must equal the number of rows in the table.
column_index
The index of the column to insert. Tables are indexed starting from 1 (1 to n columns).
To insert column 4 of type integer and label INTEGERS to "table1" which has 7 rows:
*createstringarray 7 1 2 3 4 5 6 7
*tableinsertcolumn "table1" int INTEGER 1 7 4
   # Handle error
Version History
11.0.101
