*setisosurfaceparameters
Sets the display parameters of the isosurface.
*setisosurfaceparameters on legendbased value addfacesabove transparent constantcolor color
HyperMesh Tcl Modify Command
on
A boolean value to turn the isosurface on or off.
legendbased
A boolean value to determine if the isosurface is legend based or value based.
value
The value of the value-based isosurface.
addfacesabove
A boolean value to add the "faces above" to the isosurface.
transparent
A boolean value to turn on transparency on the "faces below" the iso value.
constantcolor
A boolean value to display the isosurface in a user-specified.
color
The color of the isosurface.
None.
