*createmarklast
Populates the mark with the entities used in the last command.
*createmarklast entity_type mark_id
HyperMesh Tcl Modify Command
- entity_type
 - The type of entities to populate.
 - mark_id
 - The ID of the mark. Valid values are 1 and 2.
Examples
*createmark surfaces 1 100
*createmark lines 1 2471
*offset_surfaces_and_modify surfaces 1 0 1 -3 -0.5
*createmarklast surfaces 1
hm_getmark surfs 1Errors
   # Handle error
