*attributeupdateentitymark
Updates an attribute of type entity on a set of entities.
*attributeupdateentitymark entity type mark identifier solver status behavior targetentity targetentityid
HyperMesh Tcl Modify Command
- entity type
 - The type of entity that owns the attribute.
 - mark
 - The number of the mark.
 - identifier
 - The identifier of the attribute.
 - solver
 - The solver number of the attribute.
 - status
 - The status of the attribute.
 - behavior
 - The behavior of the attribute.
 - targetentity
 - The type of entity to which the attribute points.
 - targetentityid
 - The ID of the entity to which the attribute points.
Examples
*createmark(elements,1) 17 18
*attributeupdateentitymark(elements,1,1247,6,0,0,nodes,1)
