*CE_ErrorSet
Assign a pre-defined error code to a connector.
*CE_ErrorSet id error_code
HyperMesh Tcl Modify Command
This command assigns a pre-defined error to a connector.
- id
 - The ID of the connector.
 - error_code
 - The error code to assign to the connector. Valid values are:
- 0 - CE_ERROR_UNDEFINED
 - 1 - CE_ERROR_PROJECTIONS_LACKING
 - 2 - CE_ERROR_LINKS_UNRESOLVED
 - 3 - CE_ERROR_INCOMPLETE_REALIZATION
 - 4 - CE_ERROR_INCOMPATIBLE_FECONFIG
 - 5 - CE_ERROR_NO_TEST_POINT
 - 11 - CE_ERROR_LINK_LACKING_THICKNESS
 - 51 - CE_ERROR_AREA_LACKING_MESH
 - 61 - CE_ERROR_BOLT_HOLE_NOT_FOUND
 - 62 - CE_ERROR_BOLT_HOLE_LACKING
 - 63 - CE_ERROR_OVERLAP_1D_ELEM
 - 71 - CE_ERROR_MESH_IMPRINT_INCOMPLETE
 - 72 - CE_ERROR_MESH_IMPRINT_ACROSS_FEATURE
 - 73 - CE_ERROR_MESH_IMPRINT_OVERLAP_WITH_ITSELF
 - 74 - CE_ERROR_MESH_IMPRINT_EXTREME_CASE
 - 75 - CE_ERROR_MESH_IMPRINT_MISSING_ELEMS
 - 76 - CE_ERROR_MESH_IMPRINT_OVERLAP_WITH_OTHER
 - 77 - CE_ERROR_LESS_HEXA_HEIGHT
 - 78 - CE_ERROR_CUSTOM
 - 79 - CE_ERROR_MESH_IMPRINT_FAILED
 - 80 - CE_ERROR_NSM_PROPERTY_NOT_POSSIBLE
Examples
*CE_ErrorSet 10 80Errors
   # Handle error
}Version History
11.0.130
