*ME_ModuleOccurrenceCreate
Creates a module part or part assembly.
*ME_ModuleOccurrenceCreate name ?"option1=value1, option2=value2, ..., optionN=valueN"?
HyperMesh Tcl Modify Command
- name
 - The name of the module to create.
 - options (optional)
 - List of input options, passed as a comma separated string enclosed in quotes. Valid
            options are:
- parent_id=<id>
 - The ID of the module part or part assembly you wish to make this module a child of. If not specified, the new module is placed underneath the root model module.
 - structural_type=<type>
 - part or assembly. A part is the default if not specified, and can coverts to a part assembly. A part assembly cannot be converted to a part.
 - udm_id=<string>
 - The string ID from a UDM XML file for this part, if necessary.
Create a new Part module named "mypartname" as a child of the module with ID 2:
*ME_ModuleOccurrenceCreate mypartname "parent_id=2, structural_type=part"
   # Handle error
}Version History
14.0
