*splitelementbyedges
Splits shell element edges that are intersected by a line joining the input points.
*splitelementbyedges x1 y1 x2 y2 ?x3 y3? ... ?xN yN?
HyperMesh Tcl Modify Command
Splits shell element edges that are intersected by a line joining the input points. The user can provide x-coordinate and y-coordinate of the mouse click on the screen. The number of input points must be ≥ 2.
x1
The screen x coordinate of point 1.
y1
The screen y coordinate of point 1.
x2
The screen x coordinate of point 2.
y2
The screen y coordinate of point 2.
Examples
Example:
*splitelementbyedges 354 379 694 385
   # Handle error
Version History
2021
