*elementqualityoptimizeelementnew
Optimizes 2D element node locations to improve the element and adjacent elements' quality index according to pre-set quality criteria.
*elementqualityoptimizeelementnew element_id midnodes_flag
HyperMesh Tcl Modify Command
This command optimizes 2D element node locations to improve the element and adjacent elements' quality index according to pre-set quality criteria.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
Current element quality criteria for optimization must be set before using this command. The command may be applied at any time without resetting the current quality criteria.
element_id
The element ID.
midnodes_flag
0 - Do not consider neighboring mid-nodes during optimization.
1 - Consider neighboring mid-nodes during optimization.
To optimize the node locations of the elements with IDs 397, 432 and 102 using quality criteria from a file:
*readqualitycriteria c:/criteria/mycriteria.txt
*createmark elems 1 displayed
*elementqualitysetup 1
*elementqualityoptimizeelementnew 397 1
*elementqualityoptimizeelementnew 432 0
*elementqualityoptimizeelementnew 102 1
*elementqualityshutdown 1
   # Handle error
Version History
12.0.110
