*beamsectionsetdatastandard
Updates the data for a standard type beam section.
*beamsectionsetdatastandard parameter_array parameter_array_length beam_sect_id beam_sect_type orientation_angle beam_sect_subtype
HyperMesh Tcl Modify Command
Updating a shell beam section requires two commands of which this is the second. This command will update all data for a shell type beam section. The command *beamsectionsetdataroot should precede use of this command.
Beam section data cannot be updated piecemeal with this command; all data must be known for the beam and sent in as arguments.
Results will be calculated for the beam section automatically after updating.
- parameter_array
 - The ID of the double array that contains the standard section parameters. The double array is created using the *createdoublearray command. This should always be set to 1.
 - parameter_array_length
 - Integer indicating the size (three times the number of parameters) of the double array created using *createdoublearray.
 - beam_sect_id
 - The beam section ID to update.
 - beam_sect_type
 - Standard beam section type. Valid values are:
- 0 - Thin walled box section
 - 1 - Generic symmetric section
 - 2 - Generic non-symmetric section
 - 3 - Constant perimeter box section
 - 4 - Hat section
 - 7 - Tube section
 - 10 - Rectangle section
 - 11 - Circle section
 - 12 - Symmetric I-section
 - 13 - Channel section
 - 14 - L-section
 - 15 - T-section
 - 16 - H-section
 - 17 - Asymmetric section
 - 18 - Cross section
 - 19 - Trapezoid section
Note: Not all section types are supported for all solvers. Consult the beam_sect_subtype table below. - orientation_angle
 - Angle of rotation for the standard section. Valid values are:
- 0 - 0 degrees.
 - 1 - 90 degrees.
 - 2 - 180 degrees.
 - 3 - 270 degrees.
Section Type HyperMesh OptiStruct Nastran ANSYS Abaqus LS-DYNA Permas Samcef Box 0 0 0 0 0 0 0 0 General Symmetric 1 0 --- --- --- --- --- --- General Asymmetric 2 0 --- --- --- --- --- --- Constant Perimeter Box 3 0 --- --- --- --- --- --- Hat 4 0 270 0 --- 0 --- --- Tube 7 0 0 0 0 0 0 0 Rectangle 10 0 90 0 0 0 --- 0 Circle 11 0 0 0 0 0 --- 0 I-Section 12 0 270 0 0 0 --- 0 Channel 13 0 0 (chan2) 90 (chan)
90 (chan1)
0 --- 0 (Channel) 0 (Channel1)
90
(Channel2)
--- 0 L-section 14 0 0 0 0 0 --- 0 T-section 15 0 0 (T1) 90 (T2)
270 (T)
180 0 0 (T-shape) 90 (T-shape1)
180 (T-shape2)
--- 0 H-section 16 0 0 (I1) 90 (H)
--- --- 0 --- 90 Asymmetric 17 --- 90 0 --- 0 0 0 Cross 18 --- 0 --- --- 0 --- --- Trapezoid 19 --- --- --- 0 --- --- --- Note: Not all angles are supported for all beam sections for all Solvers. Consult the table below. The angles are shown where they differ for the full list of supported types. - beam_sect_subtype
 - The name of the section subtype. Consult the table below for supported values for each
            Solver and section type.
Section Type HyperMesh OptiStruct Nastran ANSYS Abaqus LS-DYNA Permas Samcef Box 0 HMBox Box
Box1
HREC BOX Box-shape1 Tubular box Type3 PROFIL_7 General Symmetric 1 HMGensym --- --- --- --- --- --- General Asymmetric 2 HMGennonsym --- --- --- --- --- --- Constant Perimeter Box 3 HMCpbox --- --- --- --- --- --- Hat 4 HMHat HAT HATS --- Hat-shape --- --- Tube 7 HMTube Tube CTUBE PIPE Tubular Type2 PROFIL_9 Rectangle 10 HMRect Bar RECT RECT Solid box --- PROFIL_6 Circle 11 HMCirc Rod CSOLID CIRC Circular --- PROFIL_8 I-Section 12 HMIsec I I I I-shape I-shape1
I-shape2
--- PROFIL_1B Channel 13 HMChan Chan
Chan1
Chan2
CHAN --- Channel Channel1
Channel2
--- PROFIL_2 L-section 14 HMLsec L L L L-shape --- PROFIL_3 PROFIL_3B
T-section 15 HMTsec T
T1
T2
T T T-shape T-shape1
T-shape2
--- PROFIL_5 H-section 16 HMHsec H 11
--- --- H-shape --- PROFIL_1 Asymmetric 17 --- Z Z --- --- Type1 PROFIL_4 PROFIL_4B
Cross 18 --- Cross --- --- Cross --- --- Trapezoid 19 --- --- --- TRAPEZOID --- --- ---
Examples
*beamsectionsetdataroot 1 1 0 2 7 1 0 0 0 0 0 0 0
*createdoublearray 12 6 6 6 0.5 0.5 0.5 4 4 4 1 1 1
*beamsectionsetdatastandard 1 12 1 4 0 HMHatErrors
   # Handle error
}Version History
11.0.120
