*hf_SlideHandleptrOnSectionPlane
Updates the handle position. The binder and the section are automatically identified.
*hf_SlideHandleptrOnSectionPlane handle_id x_mouse y_mouse reserved
HyperMesh Tcl Modify Command
This command updates the position of handle with ID handle_id from its current position, to the new mouse position with coordinate (x_mouse and y_mouse).
- handle_id
 - The ID of the handle to position.
 - x_mouse
 - Mouse x-coordinate of the new handle position.
 - y_mouse
 - Mouse y-coordinate of the new handle position.
 - reserved
 - Reserved for future use. Must be 1.0.
*hf_SlideHandleptrOnSectionPlane 5 1982.39933 287.781925 1Errors
   # Handle error
}Version History
10.0
