*maskreverse
Reverses the masking state of a specific entity type.
*maskreverse entity_type
HyperMesh Tcl Modify Command
Reverses the masking state of a specific entity type. For collected entities, only entities in displayed collectors are affected. This includes:
  • components (points, lines, surfaces, solids, elements, connectors)
  • points
  • lines
  • surfaces
  • solids
  • elements (both in components and groups)
  • connectors
  • groups (elements)
  • multibodies (ellipsoids, mbjoints, mbplanes)
  • ellipsoids
  • mbjoints
  • mbplanes
  • loadcols (loads)
  • loads
  • equations
  • systemcols (systems)
  • systems
  • vectorcols (vectors)
  • vectors
  • tags
  • domains
  • handles
  • morphconstraints
  • morphvolumes
  • shapes
  • symmetries
To reverse the masking of all vectors in the displayed vector collectors:
*maskreverse vectorcols
   # Handle error
Version History
9.0
