*midsurface_display_plate_sides
Creates two components that contain copies of the model surfaces belonging to two sides of a given plate.
*midsurface_display_plate_sides plate_number reserved1 reserved2
HyperMesh Tcl Modify Command
- plate_number
 - Specifies the plate number for which the plate side information is to be created.
 - reserved1
 - Reserved for future use. Must be set to 0.
 - reserved2
To show the plate information for the plate with plate number 127:
*midsurface_display_plate_sides 127 0 0
   # Handle error
}Version History
13.0
