*applydisplayattributes
Sets the components on the graphics component list (select/apply on the menu) to the specified style and color.
*applydisplayattributes style colortype
HyperMesh Tcl Modify Command
- style
 - Determines the type of graphical entities used to display the component. The options are:
- 0 - Wire frame.
 - 1 - Hidden line.
 - 2 - Hidden line with mesh.
 - 3 - Hidden line with features.
 - 4 - Hidden line transparent.
 - colortype
 - Determines how the components are colored. The options are:
- 0 - None.
 - 1 - Component color.
 - 2 - Assigned plots.
 - 3 - Contours.
