*updateinclude
Updates include file basic information.
*updateinclude id shortname_flag shortname fullname_flag fullname parentid_flag parentid
HyperMesh Tcl Modify Command
- id
 - The ID of the include file to update. If 0, the shortname is used instead.
 - shortname_flag
 - 0 - Do not update the file short name
 - shortname
 - The new short name if shortname_flag is 1, or the short name to use to select the file if id is 0.
 - fullname_flag
 - 0 - Do not update the file full name
 - fullname
 - The new full name if fullname_flag is 1.
 - parentid_flag
 - 0 - Do not update the parent ID
 - parent_id
 - The new parent ID if parentid_flag is 1.
To change the include file with ID 1, stored as C:/common_files/mats/mat1.dyn from mat1.dyn to mat2.dyn and change its parent from the main file to a file with ID 3:
*updateinclude 1 1 mat2.dyn 1 C:/common_files/mats/mat2.dyn 1 3
   # Handle error
