*tableexport
Exports data from a table to a file.
*tableexport name filename delimiter
HyperMesh Tcl Modify Command
- name
 - The name of the table to export.
 - filename
 - The full path and filename of the file to write.
 - delimiter
 - The character or string to use as the delimiter. The value must be enclosed in quotes. If not specified, the default is a comma (CSV).
Examples
To write out table1 with commas as the separator.
*tableexport table1 C:/table1.txt ","
      or
      To write out table1 with ABC as the separator.
*tableexport table1 C:/table1.txt "ABC"
   # Handle error
}Version History
11.0
