*freeshapedesvarupdatewithmethod
Updates a free shape design variable.
*freeshapedesvarupdatewithmethod entity_type mark_id name method
HyperMesh Tcl Modify Command
- entity_type
 - The type of entity used in creating the design variable. Valid values are nodes, elements, sets (nodal only), or properties.
 - mark_id
 - The ID of the mark of entities used to update the design variable. Valid values are 1 and 2.
 - name
 - The name of the design variable.
 - method
 - 0 - CLASSIC
*createmark nodes 1 2110 3292
*freeshapedesvarupdatewithmethod nodes 1 "fsh1" 2*createmark sets 1 "set1"
*freeshapedesvarcreatewithmethod sets 1 "fsh2" 0Errors
   # Handle error
}Version History
2019.1
