*CE_ConnectorSetVectorByMark
Set projection vector for connectors specified by mark.
*CE_ConnectorSetVectorByMark markmask type i j k vector node1 node2
HyperMesh Tcl Modify Command
- markmask
 - The mark of the connectors.
 - type
 - The method to set the vector:
 - i
 - 1st of 3 float number defining a vector.
 - j
 - 2nd of 3 float number defining a vector.
 - k
 - 3rd of 3 float number defining a vector.
 - vector
 - HyperMesh Vector entity ID.
 - node1
 - 1st node ID to define a vector in HyperMesh.
 - node2
 - 2nd node ID to define a vector in HyperMesh
Examples
*createmark(connectors, 1) 1, 2, 3
*CE_ConnectorSetVectorByMark(1, 1, 0, 0, 0, 3, 0, 0) Projection vector for a connector will be used during realization process.
