*linecreatedragnodealongvector
Create lines by dragging nodes or points along a direction.
*linecreatedragnodealongvector entity_type mark_id vector distance
HyperMesh Tcl Modify Command
This command creates straight segment lines by dragging nodes or points a user specified distance along a vector.
- entity_type
 - Type of entities representing input points. Valid values are nodes or points.
 - mark_id
 - The mark ID containing the input points. Valid values are 1 and 2.
 - vector
 - ID of the temporary vector created using *createvector.
 - distance
 - The distance to drag the input points.
To create 4 straight segments with endpoints at nodes 2, 4, 6 and 8, oriented parallel to the x-axis, with lengths of 1.5:
*createmark nodes 1 2 4 6 8
*createvector 1 1 0 0
*linecreatedragnodealongvector nodes 1 1 1.5
   # Handle error
}Version History
10.0
