*morphhyperpreview
Draws vectors for shapes to be created.
*morphhyperpreview typehand markhand xi yi zi xx yy zz sys sym con vvec mag type
HyperWorks Tcl Query Command
- typehand
 - Handles
 - markhand
 - Handle mark number
 - xi
 - 0 - Do not create x perturbation
 - yi
 - 0 - Do not create y perturbation
 - zi
 - 0 - Do not create z perturbation
 - xx
 - x perturbation magnitude
 - yy
 - y perturbation magnitude
 - zz
 - z perturbation magnitude
 - sys
 - System to create perturbations in (default = global)
 - sym
 - 0 - Do not use symmetry
 - con
 - 0 - Do not use constraints
 - vvec
 - Vector mark number
 - mag
 - magnitude of perturbation
 - type
 - 0 - XYZ directions
*morphhyperpreview (HANDLES,1,0,0,1,1.0,1.0,5.0,3,1,1,0,0.0,1)
      A vector is drawn for each handle on the mark in either the xyz directions, the vector direction, or the normal direction. This is used to preview the shapes that will be created in the autoshape panel before creating them. If symmetry is used, all handles linked to marked handles by symmetry will also be perturbed. If constraints are used, they will be applied to the perturbations.
None.
