*adaptive_triangle_mesh
Creates an adaptive tria mesh from an STL tria mesh input.
*adaptive_triangle_mesh entity_type mark_id options
HyperMesh Tcl Modify Command
Creates an adaptive tria mesh from an STL tria mesh input. This is useful for remeshing dirty STL meshes.
entity_type
The type of entity to remesh. Valid values are comps and elems.
mark_id
The ID of the mark containing the input entities. Valid values are 1 and 2.
options
The options to control the new mesh generation. They are all key=value pairs. Pairs are separated by either a space or a comma. Valid parameters are:
break_connectivity=<value>
Option to manage the connectivity with the neighboring mesh:
0 – Fix nodes on selection boundary as well as other edges
1 – Break the connectivity at the selection boundary
2 – Keep the connectivity at the selection boundary
3 – Redo connectivity outside the selection, the spread of the transition region is determined automatically till the size meets neighbouring size
dfmin=<value>
The minimum elem size.
feature_angle=<value>
The minimum angle used to define features to keep in the resulting mesh. Default is 35.0 degrees.
growth_ratio=<value>
The growth ratio of the triangles. Default is 1.2.
inside=<value>
The fixed number of layers of elements inside the element selection where the connectivity is redone. This is valid only when break_connectivity=3.
outside=<value>
The fixed number of layers of elements outside the element selection where the connectivity is redone. This is valid only when break_connectivity=3.
ref_size=<value>
The default elem size.
span_angle=<value>
Defines the maximum angle an element can span on a curved section. Default is 25.0 degrees.
Examples
To create a new adaptive mesh of comp "remesh" with new mesh size 10, minimum size 1.0, growth ratio 1.2, span angle 30 degrees and feature angle 30 degrees:
*createmark comps 1 "remesh"
*adaptive_triangle_mesh comps 1 "growth_ratio=1.2 span_angle=30.0 feature_angle=30.0 ref_size=10.0 dfmin=1.0"
   # Handle error
Version History
14.0
2021 - Added new options optional values break_connectivity, inside and outside.
