*morphdomainautocolor
Automatically assign a different color to selected domains.
*morphdomainautocolor entity_type mark_id
HyperMesh Tcl Modify Command
This command will set the color of selected domains to be a different value if possible. All 64 colors will be used, except for black, before the same color is used a second time.
entity_type
Must be set to domains.
mark_id
The ID of the mark containing the domains. Valid values are 1 and 2.
To assign a different color to a number of domains:
*createmark domains 1 6 15 154 153 68 143 211 208 185 184 167 157
*morphdomainautocolor domains 1
   # Handle error
Version History
12.0.110
