*tableupdatecell
Updates the value of a cell in a table.
*tableupdatecell name row_index column_index value
HyperMesh Tcl Modify Command
- name
 - The name of the table to update.
 - row_index
 - The index of the row to edit. Tables are indexed starting from 1 (1 to n rows).
 - column_index
 - The index of the column to edit. Tables are indexed starting from 1 (1 to n columns).
 - value
 - The value to update.
To update cell (3.4) of table1:
*tableupdatecell table1 3 4 100.2345
   # Handle error
}Version History
11.0
