*morphupdatedisplay
Updates the display of morphing entities.
*morphupdatedisplay type mode
HyperMesh Tcl Modify Command
- type
 - 0 = all morphing entities
 - mode
 - 0 = turn off
*morphupdatedisplay (0,0)
      Note that if the type is set to zero (all morphing entities) the mode will be the same for all types.
None.
