*adaptive_wrapper_set_features
Assigns/extracts features for the adaptive wrapper mesher.
*adaptive_wrapper_set_features feature_type mark_id feature_angle clean_features cleanup_tol
HyperMesh Tcl Modify Command
This command assigns/extracts features for the adaptive wrapper mesher.
This command must be called after *adaptive_wrapper_init and before *adaptive_wrapper_build.
- feature_type
 - The feature extraction scheme. Valid values are:
 - mark_id
 - The mark ID containing user-defined plotel feature elements. Valid values are 1 and 2.
 - feature_angle
 - If feature_type is 1 or 2, this is the feature angle used for feature extraction.
 - clean_features
 - 1 - Cleans features based on feature overlap. This is used to avoid excessive refinement.
 - cleanup_tol
 - If clean_feature is 1, this is the tolerance used to check for feature overlap.
Examples
#Initialization of wrapper mesh with base mesh
*createmark elements 1 "all"
*adaptive_wrapper_init elements 1 1 0
# Define features
*clearmark elements 1
*adaptive_wrapper_set_features 1 1 30 1 1
#Set various meshing and refinement parameters
*createstringarray 7 "LeakCheckNodes: 20 24 19" "GapPatchTolerance: 3.0" "HolePatchTolerance: 10.0" "RefineByBoxCompIds: 4 5 6" "RefineByNodeCurvature: 1" "RefineByFeatureProximity: 0" "RefineByAllElemSize: 1"
*adaptive_wrapper_set_params 10 0.1 1 7
#Proximity options
eval *createstringarray 3 "WithinGroup: 0.5 1 3 10 12 13" "WithinGroup: 1.5 3 9 20" "AcrossGroup: 0.5 3 10 12 13 4 9 8 7 19"
*adaptive_wrapper_proximity_params 1 0.2 1 3
#Build skeletal octree structure
#Generate mesh
*createstringarray 2  "DoRemesh: 1" "RemeshGrowthRate: 1.2"
*adaptive_wrapper_mesh 0 1 2
#End of wrapper mesh
*adaptive_wrapper_end
   # Handle error
}Version History
13.0
