*barelementupdatewithoffsets
Updates the vector, pin flags, property, direction node and offset for multiple bar and/or bar3 elements.
*barelementupdatewithoffsets mark_id update_vector vector_option vector_id update_pins pin_flags_a pin_flags_b update_property property_name update_orientation orientation_node y_dir update_offset_a offset_system_a offset_x_a offset y_a offset_z_a update_offset_b offset_system_b offset_x_b offset_y_b offset_z_b
HyperMesh Tcl Modify Command
- mark_id
 - The ID of the mark containing the bar and/or bar3 elements to update. Valid values are 1 and 2.
 - update_vector
 - If non-zero, vector_id is used to update the local y-axis.
 - vector_option
 - 0 - Vector is defined by using global coordinate system.
 - vector_id
 - The ID of the y-axis vector to use, defined using the *createvector command. If used, this must be set to 1.
 - update_pins
 - If non-zero, pin_flags_a and pin_flags_b are used to update the pin flags.
 - pin_flags_a
 - The pin flags at end a. A pin flag of 0 passes forces in all degrees of freedom.
 - pin_flags_b
 - The pin flags at end b. A pin flag of 0 passes force in all degrees of freedom.
 - update_property
 - If non-zero, property_name is used to update the property.
 - property_name
 - The name of the property collector assigned to the bar.
 - update_orientation
 - If non-zero, the direction node will be updated.
 - orientation_node
 - The orientation node ID. y_dir specifies whether this node defines the local y- or local z-axis.
 - y_dir
 - If set to 1, then orientation_node defines the local y-axis of the bar. Otherwise, orientation_node defines the local z-axis.
 - update_offset_a
 - If non-zero, the offsets at end a are updated.
 - update_offset_b
 - If non-zero, the offsets at end b are updated.
 - offset_system_a
 - The system used to define the offsets at end a. Valid values are:
- 0 - Offsets given in global coordinate system.
 - 1 - Offsets given in local coordinate system of node1.
 - 2 - Offsets given in elemental coordinate system.
 - offset_x_a
 - The offset in the x-direction at end a.
 - offset_y_a
 - The offset in the y-direction at end a.
 - offset_z_a
 - The offset in the z-direction at end a.
 - offset_system_b
 - The system used to define the offsets at end b. Valid values are:
 - offset_x_b
 - The offset in the x-direction at end b.
 - offset_y_b
 - The offset in the y-direction at end b.
 - offset_z_b
 - The offset in the z-direction at end b.
Examples
*createvector 1 0.0000 1.0000 0.0000
*barelementupdatewithoffsets 1 1 0 1 0 0 0 0 "" 0 0 0 0 0 0.0 0.0 0.0 0 0 0.0 0.0 0.0*barelementupdatewithoffsets 1 1 2 1 0 0 0 0 "" 0 0 0 0 0 0.0 0.0 0.0 0 0 0.0 0.0 0.0*barelementupdatewithoffsets 1 0 0 1 0 0 0 0 "" 1 3 1 0 0 0.0 0.0 0.0 0 0 0.0 0.0 0.0*barelementupdatewithoffsets 1 0 0 1 0 0 0 0 "" 0 0 0 1 0 0 0.2 0.2 0.2 1 0 0.3 0.3 0.3Errors
   # Handle error
}Version History
11.0
