*delaunay_2d_3d
Performs 2D/3D triangulation of selected nodes.
*delaunay_2d_3d type entity_type mark_id reserved
HyperMesh Tcl Modify Command
type
The type of triangulation to perform.
2 - 2D triangulation
3 - 3D triangulation
entity_type
Must be set to nodes.
mark_id
The ID of the mark containing the input entities. Valid values are 1 and 2.
reserved
Reserved for future use. Must be set as "".
Examples
To 2D triangulate the displayed nodes:
*createmark nodes 1 displayed
*delaunay_2d_3d 2 nodes 1 ""
   # Handle error
Version History
2019
