*createbestcirclecenternode
Creates a node or a point at the center of the circle that best approximates the input set of lines or points.
*createbestcirclecenternode entity_type mark_id point_flag any_tol make_circle
HyperMesh Tcl Modify Command
This command creates a node or a point at the center of the circle that best approximates the input set of lines or points. If the input entities are found to be on a straight line, then an error is returned.
- entity_type
 - Input entity types. Valid values are:
- Nodes
 - Points
 - Lines
 - mark_id
 - The ID of the mark containing the input entities. Valid values are 1 and 2.
 - point_flag
 - Parameter specifying whether a node or point is created at the approximated circle
            center. Valid values are:
- 0 - Create node.
 - 1 - Create point.
 - any_tol
 - Parameter specifying whether the best fit is verified against the currently set
            geometry cleanup tolerance. Valid values are:
- 0 - An error is returned, if the input entities are not on the circle within the geometry cleanup tolerance.
 - 1 - Tolerance is ignored and best fit circle is always calculated.
 - make_circle
 - Parameter specifying whether a circle is also created:
- 0 - Only center point/node is created.
 - 1 - Center point/node and a circle are created.
Examples
*createmark nodes 1 11 12 14
*createbestcirclecenternode nodes 1 0 1 0*createmark lines 1 21
*createbestcirclecenternode lines 1 1 1 1Errors
   # Handle error
}Version History
10.0
