*jointelement_twonoded
Creates a spherical or two-noded joint element.
*jointelement_twonoded n1 n2 orientation o_node1 o_node2 system1 system2 property
HyperMesh Tcl Modify Command
n1,n2
The two nodes of the element.
orientation
Orientation option for the element. Use:
  • 0 - None
  • 1 - Systems
  • 2 - Nodes
o_node1,2
The orientation node IDs for the element.
system1,2
The orientation systems’ IDs for the element.
property
The property to which the element points..
To create a two-noded joint element:
*jointelement_twonoded(320,303,2,322,324,0,0,"shells")
None.
