*clearallidranges
Clears all ID ranges for various portions of a model.
*clearallidranges id_or_type mode
HyperMesh Tcl Modify Command
id_or_type
The submodel ID or entity type, depending on the requested mode.
mode
bymodel - Clear all ID ranges in the whole model.
bysubmodel - Clear all ID ranges in a submodel.
byentities - Clear all ID ranges on an entity type in the whole model.
byexcludedmodel - Clear all excluded IDs in the whole model.
byexcludedsubmodel - Clear all excluded IDs in a submodel.
byexcludedentities - Clear all excluded IDs on an entity type in the whole model.
Examples
To clear all ID ranges for the whole model:
*clearallidrange 0 bymodel
To clear all ID ranges for an include:
*clearallidrange $include_id bysubmodel
To clear ID ranges for all comps in the model:
*clearallidrange comps byentities
To clear all excluded IDs in the whole model:
*clearallidrange 0 byexcludedmodel
To clear all excluded IDs in an include
*clearallidrange $include_id byexcludedsubmodel
To clear excluded in an entity type cross the model:
*clearallidrange groups byexcludedentities
   # Handle error
Version History
14.0.110
