*rigidwall_geometry
Adds geometric definition to a rigid wall.
*rigidwall_geometry name geometrytype basenode vectors n1 n2 geomvar1 geomvar2 geomvar3
HyperMesh Tcl Modify Command
- name
 - The name of the rigid wall.
 - geometrytype
 - Use:
- 1 infinite plane
 - 2 finite plane
 - 3 infinite prism
 - 4 finite prism
 - 5 cylinder
 - 6 sphere
 - 7 MADYMO plane
 - 8 MADYMO ellipse
 - basenode
 - The ID of the base node for the rigid wall.
 - vectors
 - The normal vector.
 - n1, n2
 - The ID of the nodes used to define the rigid wall.
 - geomvar1
 - The length in the x directon or radius. This is also used for the MADYMO plane/ellipse ID value.
 - geomvar2
 - The length in the y direction.
 - geomvar3
 - The length in the z direction.
None.
