*update1delements
Updates 1D beams, bars and rods, and optionally assigns properties. Alternately, properties and offset can be calculated from a section cut on the model.
*update1delements <option1>=<value1> <option2>=<value2> ... <optionN>=<valueN>
HyperMesh Tcl Modify Command
Updates 1D beams, bars and rods, and optionally assigns properties. Alternatively, updates the element property and offset as the result of a section cut on target entities (geometry or elements). This computes sectional properties and materials from intersected entities. Orientation remains unchanged and the offset is calculated in elemental system from elements position relative to calculated shear center. This option is exclusive and can’t be used along with regular orient, offset, property update.
- adjustoffset=<value>
- Adjust the offset when offsetflag=1. Valid values are all, reset and vert.
- allshells=<value>
- Flag to consider all neighboring shells. For orientation, use usereference=1, orientflag=1 and orientmethod=auto. For offset, use usereference=0 and offsetflag=1.
- connectiontol=<value>
- The maximum distance for autoweld on two separated domain loops. Its only applied to inflated domains (surface cut and 2D element cut). Used only when updating 1D elements using a section cut.
- consolidateprops=<value>
- Flag to define if properties should be consolidated. Used only if consolidationtol is equal or greater than 0.0.
- consolidationtol=<value>
- The tolerance value (percentage) to consolidate similar beam sections while applying a section cut. If the maximum relative variation for the area, inertias and warping constant between two beam sections is less than the tolerance value, both beam sections are considered as equivalent. In that case, only one unique beam section is created.
- contacttol=<value>
- The maximum contact distance between two separated domains; applies to meshed domains. Use only when updating 1D elements using a section cut. Default -1.0.
- createpropfromdata=<flag>
- Used to create property from metadata. Used only when propflag=1, usereference=1 and propmethod=bydata.
- cutlocation=<label>
- Section cut location. Used only when updating 1D elements using a section cut.
- detatchelements=<label>
- Flag to define if 1D elements should be detached from model. If true and if the 1D element is sharing a node with 2D or 3D elements, then the start and/or end node is duplicated.
- inputentitytype=<entity_type>
- The type of input entity. Valid value is elems. Used only when usereference=0.
- inputmark=<mark_id>
- The ID of the mark of input entities. Valid values are 1 and 2. Used only when usereference=0.
- offsetends=<method>
- The method of offsetting element ends. Used only when offsetflag=1. Valid values are start (offset at start/end A), end (offset at end/end B), and startend (offset at both ends).
- offsetflag=<flag>
- 0 - Do not update element offset values
- offsetlateral=<value>
- The lateral offset direction. Valid values are pos or neg. Used when offsetflag=1.
- offsetmethod=<method>
- The element offset method. Used only when offsetflag=1. Valid values are
- offsetnormal=<value>
- The normal offset direction. Valid values are pos or neg. Used when offsetflag=1.
- orient=<value>
- 0 - Do not update element orientation using autoupdate1delements
- orientdatatype=<method>
- Provide a label as metadata, which uses inclination information stored as metadata. Used only when orientflag=1, usereference=1 and orientmethod=bydata.
- orientflag=<flag>
- orientmetadataent=<entity_type>
- The entity type to use for metadata. Valid value is lines. Used only when orientflag=1, usereference=1 and orientmethod=bydata.
- orientmetadatamark=<mark_id>
- The ID of the mark for orientmetadataent. Used only when orientflag=1, usereference=1 and orientmethod=bydata.
- orientmetadataname=<label>
- Provide a label as metadata name where orientation inclination exists. Used only when orientflag=1, usereference=1 and orientmethod=bydata.
- orientmetadatatype=<label>
- Provide a label as byentity, to use metadata from the entity. Used only when orientflag=1, usereference=1 and orientmethod=bydata.
- orientmethod=<method>
- The element orientation method. Valid values are auto (normal to plates), bydata, bynodeid, and bysystem. Used only when orientflag=1.
- orientnodeid=<id>
- The ID of the orientation node. Used only when orientflag=1 and orientmethod=bynodeid
- orientsysid=<id>
- The ID of the orientation system. Used only when orientflag=1 and orientmethod=bysystem
- orientvector=<id>
- The ID of the orientation vector. Used only when orientflag=1 and orientmethod=bysystem
- planebase={<value>}
- Location of the plane for the section cut. Used only when cutlocation is not provided and when updating 1D elements using a section cut.
- planeheight=<value>
- Height of the plane to define finite plane for the section cut. Used only when updating 1D elements using a section cut.
- planenormal={<value>}
- Normal of the plane for the section cut. Used only when cutlocation is not provided and when updating 1D elements using a section cut.
- planewidth=<value>
- Width of the plane to define finite plane for the section cut. Used only when updating 1D elements using a section cut.
- propdatalabel=<label>
- Provide a label as metadata, which uses property information stored as metadata. If beam section exists, then a beam property is created. If thickness exists, then a shell property is created. Used only when propflag=1, usereference=1 and propmethod=bydata.
- propflag=<flag>
- Used to update the property on the elements or components.
- propid=<id>
- The ID of the property to apply to elements or components. Used only when propflag=1 and propmethod=byid.
- propmetadataentitytype=<entity_type>
- The entity type to use for metadata. Valid value is lines. Used only when propflag=1, usereference=1 and propmethod=bydata.
- propmetadatamark=<mark_id>
- The ID of the mark for propmetadataentitytype. Used only when propflag=1, usereference=1 and propmethod=bydata.
- propmetadatatype=<label>
- Provide a label as byentity, to use metadata from the entity. Used only when propflag=1, usereference=1 and propmethod=bydata.
- propmethod=<method>
- The method of updating the property. Valid values are bydata and byid. Used only when propflag=1.
- refentid=<entity_id>
- The ID of the material to be assigned to the 1D property. Used only when updating 1D elements using a section cut.
- refentmark=<mark_id>
- The ID of the mark of reference entities. Valid values are 1 and 2. Used only when usereference=1.
- refentname=<name>
- The name of the material to be assigned to the 1D property. Used only when updating 1D elements using a section cut.
- refentsearchtol=<tolerance>
- The search tolerance used by the reference entity (default -1). Used only when usereference=1.
- refenttype=<entity_type>
- The type of reference entity. Valid entities are lines and materials. Used only when usereference=1. Materials is only supported when updating 1D elements using a section cut.
- refmethod=<method>
- Use metadata from the input entity. Valid value is byentity. Used only when usereference=1.
- taperangle=<value>
- Angle between the adjacent 1D elements. Used only when cutlocation=taper.
- targetenttype=<entity_type>
- The type of target entity. Valid values are elements, surfaces, and solids. Used only when updating 1D elements using a section cut.
- targetmark=<mark_id>
- The ID of the mark for target entities. Valid values are 1 and 2. Used only when updating 1D elements using a section cut.
- thickness=<method>
- The method of assigning shell thickness in case multiple neighboring shells have different thickness values. Used only when offsetflag=1. Valid values are avg, max and min.
- translatebeam=<value>
- New position to translate the 1D element after executing a section cut.
- usercompsbydata=<flag>
- Used only when propflag=1 and either propmethod=bymethod and usereference=1, or propmethod=byid.
- usereference=<flag>
- 0 - Update elements from user input (default).
Examples
*createmark elements 1 300-305
*createmark elements 2 586-591 619-638 652-658*update1delements inputenttype=elems inputmark=1 targetenttype=elems targetmark=2 planebase={700 0 0} planenormal={1 0 0} refentid=1 connectiontol=0.0 contacttol=-1.0 consolidationtol=10.0 consolidateprops=1*update1delements inputenttype=elems inputmark=1 targetenttype=elems targetmark=2 planebase={502.6 206.1 38} planenormal={0 0 -1} planewidth=200 refentid=1 planeheight=200 connectiontol=0.0 contacttol=-1.0 detatchelements=1 translatebeam=shearcenter*update1delements inputenttype=elems inputmark=1 targetenttype=elems targetmark=2 cutlocation=0.5 connectiontol=0.0 contacttol=-1.0 detatchelements=1 translatebeam=shearcenter*update1delements inputenttype=elems inputmark=1 targetenttype=elems targetmark=2 planewidth=10 planeheight=10 cutlocation=0.5 connectiontol=0.0 contacttol=-1.0*update1delements inputenttype=elems inputmark=1 targetenttype=elems targetmark=2 cutlocation=taper taperangle=15 connectiontol=0.0 contacttol=-1.0*update1delements inputenttype=elems inputmark=1 targetenttype=elems targetmark=2 planewidth=10 planeheight=10 cutlocation=taper taperangle=15 connectiontol=0.0 contacttol=-1.0*createmark elems 1 "by config" bar2
*update1delements inputenttype=elem inputmark=1 offsetflag=1 offsetmethod=tooriginErrors
# Handle error
}Version History
2020
2021.1 Added new options connectiontol, contacttol, cutlocation, planebase, planeheight, planenormal, planewidth, refentid, refentname, refentsearchtol, refenttype, taperangle, targetenttype, and targetmark.
2021.2 - Added new options consolidationtol, consolidateprops, detatchelements, and translatebeam.
2022 - Added new values "tocentroid" and "toorigin" to the offsetmethod option.
