*createpositionformech
Creates a new position for a mechanism.
*createpositionformech name
HyperMesh Tcl Modify Command
The mechanism must have the enabled flag set to true for this to be possible.
name
The name of the position to be created. If the provided name already exists, an incremental name will be used.
To create a new position with name newposition:
*createpositionformech newposition
   # Handle error
Version History
14.0.120
