*applybeamsection
Applies a beamsection to selected members or membersections.
*applybeamsection beamsection=<beamsection_id> enttype=<entity_type> mark=<mark_id>
HyperMesh Tcl Modify Command
Applies a beamsection to selected members or membersections. If a beamsection is applied to members, a new membersection containing the beamsection is created and assigned to the members.
The beamsection entity ID to assign to the selected skeleton entities.
The entity type of selected entities to assign a beamsection. Valid values are members and membersections.
mark=<mark_id>
The ID of the mark containing the entities to assign a beamsection. Valid values are 1 and 2.
Examples
To apply a beamsection to displayed members:
*createmark members 1 displayed
*applybeamsection enttype=members mark=1 beamsection=16
   # Handle error
Version History
2022
