*savefailednodesvectors
Saves the location, magnitude, and direction of the penetrated areas.
*savefailednodesvectors mark reduction scale segment magnitude_mode
HyperMesh Tcl Modify Command
- mark
 - The mark of entity to be modified.
 - reduction
 - The average thickness reduction.
 - scale
 - The thickness scale factor.
 - segment
 - The segment orientation option.
 - magnitude_mode
 - Determines if a magnitude percentage or a uniform size is to be used.
- 1 magnitude percentage
 - 0 uniform size
To save the information of the penetration areas:
*createmark(groups, 1) "E2E"
*savefailednodesvectors(1,0,1,1,0)
      *createmark() and *templatefileset() are required.
None.
