*addfacestocontactsurfusingfacenumber
Adds elements using the face number to a contact surface.
*addfacestocontactsurfusingfacenumber name mark_id face_number reverse_normals ?element_id? ?use_element_id?
HyperMesh Tcl Modify Command
name
The name of the contact surface to update.
mark_id
The mark ID that contains the elements to add. Valid values are 1 and 2.
face_number
The face number of the element (starting from 0).
reverse_normals
0 - Create contact surface along element normal.
1 - Create contact surface opposite element normal.
element_id
The single element ID to use (default is 0).
use_element_id
0 - Use mark_id (default).
1 - Use element_id.
Examples
To add elements 1 through 100 using face number 2 to contactsurf "test":
*createmark elems 1 1-100
*addfacestocontactsurfusingfacenumber "test" 1 1 0 0 0
   # Handle error
Version History
11.0.101
2019 - Added new optional arguments element_id and use_element_id.
