*lastsimulation
Sets the last simulation and data type for transient animations.
*lastsimulation simulation data_type
HyperMesh Tcl Modify Command
Sets the last simulation and data type for transient animations. The results file must be loaded before executing this command.
simulation
The name of the simulation contained in the results file.
data_type
The name of the data type for the simulation.
To load the result file named C:/my_results/test.res and generate a rendered animation for Subcase 1 through Subcase 4 with Displacements data type, using a 10.0 model unit scaling:
*analysisfileset C:/my_results/test.res
*inputsimulation "Subcase 1" "Displacements"
*lastsimulation "Subcase 4" "Displacements"
*animatetransient "" 10.0 4 1 0
*freesimulation
   # Handle error
