*masknotshown
Masks all supported entities not in the current view window.
*masknotshown
HyperMesh Tcl Modify Command
Masks all supported entities not in the current view window. For collected entities, only entities in displayed collectors are affected. This includes:
points
lines
surfaces
solids
elements (both in components and groups)
connectors
ellipsoids
mbjoints
mbplanes
loads
equations
systems
vectors
tags
domains
handles
morphconstraints
morphvolumes
shapes
symmetries
To mask all supported entities in the displayed collectors that are not in the current view window:
*masknotshown
None.
