*entitybundleaddmark
Adds the entities on a mark to a data item of an entity bundle.
*entitybundleaddmark name data_item entity_type mark_id
HyperMesh Tcl Modify Command
name
The name of the entity bundle to be modified.
data_item
The data item of the entity bundle to be modified. Note that these indices start with 0.
entity_type
The entity type of the mark to be used. This, currently, must match the entity type for the data item as was specified in the definition of the entity bundle.
mark_id
The ID of the mark containing the entities to add to the bundle. Valid values are 1 and 2.
To add all comps in the model to the first data item of the bundle "compbundle":
*createmark components 1 all
*entitybundleaddmark "compbundle" 0 components 1
   # Handle error
Version History
14.0.130
