*solidmesh9lines
Creates a solid mesh on a volume formed by nine lines.
*solidmesh9lines lines density1 density2 density3
HyperMesh Tcl Modify Command
- lines
 - The line list ID which contains lines that define a solid.
 - density1
 - The density of the elements in the first direction.
 - density2
 - The density of the elements in the second direction.
 - density3
 - The density of the elements in the third direction.
To create a solid mesh in the volume formed by connected lines 10, 11, 12, connected lines 1, 2, and 3, and connecting lines 20, 21, and 22, with densities 3, 8 and 12:
*createlist(lines,1) 10 11 12 1 2 3 20 21 22
*solidmesh9lines(1, 3, 8, 12)
None.
