*solid_cavity_detect_fill
Creates solids from detected cavities and optionally merges the created solids with the parent.
*solid_cavity_detect_fill mark_id merge_flag
HyperMesh Tcl Modify Command
The command *solid_cavity_detect_start must be called before calling this command to generate the cavities as region entities.
- mark_id
 - The ID of the mark containing the region entities with the cavities to fill. Valid values are 1 and 2.
 - merge_flag
 - 1 - Merge new solids with parent.
Examples
Create a solid representing the cavity attached to a region 10:
*createmark regions 1 10
*solid_cavity_detect_fill 1 0
      Merge all identified cavities with the parent body:
*createmark regions 1 all
*solid_cavity_detect_fill 1 1
   # Handle error
}Version History
2019
